We are currently using FME to run the process to convert GDA94 Zone 55 ( EPSG : 28355) ECW file into GDA2020 Zone 55 ( EPSG : 7855) , the output ECW was projected to the right location, but the CRS was not recognized by QGIS or other GIS platform. I have the FME bench as attached for your reference, could you please let me know if I missed any configuration settings or should use different transformer?
