How can you reference Esri ArcGIS Online Feature Layer URL in FME?
I'm using a FeatureWriter set to Esri ArcGIS Online Feature Service to publish a Feature Layer having a polyline layer to AGOL. How can I reference the polyline layer URL in FME right after it gets published?
Best answer by JennaKAtSafe
Hi @osdev​, Currently this information (Layer URL) is not exposed in any attribute. It might be mentioned only in the log somewhere.
I've went ahead and created an idea on the community on your behalf. Feel free to add any comments to the idea If I've missed any details.
JennaKAtSafe
  • June 2, 2022
  • June 8, 2022
@jennaatsafe​ That's unfortunate, but thank you for following up and adding it as an idea.
