To map month in number to month in alphabets For Example) mapping 01/01/2018 to 01/jan/2018
Best answer by erik_jan
This can be done using the DateFormatter transformer, using these settings:
erik_jan
Forum|alt.badge.img+17
  • January 9, 2018
gio
Forum|alt.badge.img+15
  • January 9, 2018
the help shows U the format strings
fmelizard
Forum|alt.badge.img+18
  • January 9, 2018
If you are working with FME 2017.1 or above then it will be the DateTimeConverter (will look like below). Note the 'quick guide' section. Also if you want to learn more about the Date/Time stuff you can read this section of the Doc: https://docs.safe.com/fme/2017.0/html/FME_Desktop_Documentation/FME_Transformers/Transformers/dateformatter.htm
  • January 10, 2018
Thanks for your solution.
