Replace space with specific character based on the position of the space into the attribute
  • November 25, 2018
  • 123 views
boubcher
Forum|alt.badge.img+11
Hello there I
I have an attribute with the values like this (24 16 17.2) or this ( 25 7 17.2) we need to replace the first space with a letter A and second space with letter B and add letter W at the end we should get a result like this (24A16B17.2W) and this ( 25A7B17.2W) for the second case
Any idea, please
Thanks
Best answer by takashi
I would use the StringReplacer with this setting.
  • Mode: Replace Regular Expression
  • Text to Replace: ^(\\S+)\\s(\\S+)\\s(.+)$
  • Replacement Text: \\1A\\2B\\3W
danilo_fme
Forum|alt.badge.img+45
  • November 25, 2018
Hi @boubcher
I created here a example with your case:
1) Use the AttributeManager to created these two situations of Attributes
2) Split the Attributes and concactenate the values of the lists:
3) Results in FME Data Inspector:
Attached the Workspace Workspace_Replacer.fmw
Thanks,
Danilo
  • November 25, 2018
boubcher
  • November 26, 2018
@takashi
Thanks Takashi I am new to those expressions could please let me know how this work and how do you come up with the replacement text format
Thanks again
  • November 26, 2018
There are many resources about Regular Expressions. e.g.
