Archived
Create a breakpoint that saves all of the data up until that point, so when you
Related products:FME Form
***Note from Migration:***
Original Title was: Create a breakpoint that saves all of the data up until that point, so when you run the workbench again it will continue from that point instead of starting over from the beginning.
rylanatsafe
Forum|alt.badge.img+13
  • August 29, 2017
Hi @emain - great idea; thank you for posting! I encourage you to watch ~42:30 of the Sneak Peek at FME 2018 and the Road Beyond. Hopefully there is something there that might excite you..!
rylanatsafe
  • August 29, 2017
I've seen this idea – or those similar to it – pop up a few times here in the Knowledge Center.. please consider viewing the other related Ideas below and cast your vote!
Thank you for contributing to the FME Community!
jdh
Forum|alt.badge.img+28
  • August 30, 2017
In the meantime, you should look at the transformers Recorder and Player. Very useful when developing.
