Geopackage data to Geodatabase with right attributs
  • September 27, 2023
  • 206 views
Hello! I have problem to write several geopackage data to one geodatabase. I used Attribute filter and Dynamic writers. Attributes from all objects comes to each features. How to write data to geodatabase so that there are each features has own attributes?
I am not profs with FME yet :)
Would be thankful for tips.
evieatsafe
  • September 28, 2023
Hi @di_777​ thanks for your question! You may need to use a SchemaScanner so that you can use the Schema Source and Schema Definition Name (in the dynamic writer shown in your image). Here's some resources on how you can achieve this:
Happy to help!
Happy to help!
Thank you!!! I will try it.
Happy to help!
Is SchemaScanner possible to apply to geometry objects? I have FeatureTypes in my Reader (geometry+object type+attribute/schema).
