It is possible to remove "FME_MF_DIR" from User Parameters?
My parameter says this.
$(FME_MF_DIR)\\CF\\PNM.sde
But I want it to say this.
C:\\Users\\USERNAME\\Desktop\\CF\\PNM.sde
Can this be done? This is a problem because it breaks the connection when the workbench is put in different folder.
Best answer by dustin
If your .sde is in the same folder as the workspace is saved, move the .sde to a different folder. FME searches the folder the workspace resides in for source files and uses $(FME_MF_DIR) if one is found...which is helpful in some cases, but not in others. More info here: FME_MF_DIR predefined parameter (macro) (safe.com)
dustin
Forum|alt.badge.img+30
  • October 25, 2022
  • October 25, 2022
Thank you
