FME23 vs Arcgis Data Interoperability
checcosisani
Forum|alt.badge.img+12
Hi
do you know when FME23 will be available in Arcgis Data INteroperability ?
Thx
Francesco
  • June 22, 2023
I believe Safe Software retired the Data Interoperability edition in late 2020, you'll have to contact your local FME reseller for more information.
checcosisani
  • June 23, 2023
Hi
this is the release that I'm using now
  • June 23, 2023
checcosisani wrote:
Hi
I think you'll have to contact your FME reseller for the final word, unless someone from Safe would like to chime in here.
salvaleonrp
Forum|alt.badge.img+15
  • June 26, 2023
FME:23 will be available with ArcGIS for Data Interoperability for ArcGIS Pro 3.2 this fall.
saraatsafe
Forum|alt.badge.img+8
  • June 26, 2023
Hi @checcosisani​, to add to what @Renato Salvaleon​ and @david_r​ have said, Safe retired the FME Data Interop edition back in 2020. The Data Interop extension is now only sold and supported by Esri, and you can keep tabs on the versions here. Hope this helps!
