Feature reader (CSV) can't handle arithmethic expression and fails
fdw
I'm using a feature reader to read a bunch of CSV's with changing column and data row numbers. I first extract the row numbers with a text file reader en feed these values into a feature reader. Like so:
feature reader setup
When running the workspace it looks like FME interprets my expression as a text:
feature reader error
Using FME 2020.1 here. Does anyone know what is wrong? The feature reader only allows for arithmetic expressions so no option to enter text in the "Data Start Line" field
Freek
Best answer by fdw
It works when you change the formula to @Evaluate(@Value(text_line_number)+3) but I expected FME to do that for me since I used an Arithmetic Editor.
Perhaps a small bug
davtorgh
Forum|alt.badge.img+10
  • August 20, 2020
Hi @fdw​ ,
can you please provide a sample data?
fdw
  • August 21, 2020
Perhaps a small bug
mark2atsafe
Forum|alt.badge.img+43
  • August 21, 2020
Perhaps a small bug
Sounds like it. I'll check it out and file an issue with our developers.
mark2atsafe
  • August 21, 2020
Filed as FMEDESKTOP-10638
