How To Switch Workflow Base on the Attribute Valye
  • Apr 7, 2025 5:56 PM UTC
  • 127 views
fmelearner
Forum|alt.badge.img+3
Can you please let me know how I can switch and select the workflow based on the value of Attribute? For example I need to select and continue between continuing PythonCaller or PythonCaller_2 based on the value of operation
IF ‘operation’ == ‘ADD’ THEN Continue with PythonCaller
IF ‘operation’ == ‘REMOVE’ THEN Continue with PythonCaller_2
Best answer by panda
I think you can add TestFilter after attribute manager with the logic you need and connect output of each one to python caller accordingly.
panda
Forum|alt.badge.img+20
  • Apr 7, 2025 7:34 PM UTC
Forum|alt.badge.img+63
Yes, that’s pretty much it.
