fme_geometry undefined when writing to fgdb
crutledge
Forum|alt.badge.img+33
I am having trouble writing a few rasters to a raster fgdb. Most are fine but a generate errors of undefined. But previous definition seems fine. bit of a stumper. don’t think it’s a projection issue. Any thoughts?
Error on write for 1 or 2 rasters
Previous step has all as fme_aggregate and fme_type as raster.
Best answer by AliAtSafe
Hi, ​@crutledge.
Thanks for posting to the community forums!
The File Geodatabase API (FILEGDB) format does not support rasters. We do have a File Geodatabase based writers for Raster Datasets and Mosaic Datasets (these are very different than each other, and possibly may not fit your needs).
Raster Dataset - Giant single rasters that can rasters mosaic-ed into them.
Mosaic Dataset - table consisting of points to rasters stored elsewhere, that can be read as a raster catalog (table/list of rasters) or a large single mosaic-ed one.
These two writers require an ArcGIS install and license to work.
Hope this helps! Let me know if you have any questions.
<strong>This post is closed to further activity.</strong><br /> It may be a question with a best answer, an implemented idea, or just a post needing no comment.<br /> If you have a follow-up or related question, please <a href="https://community.safe.com/topic/new">post a new question or idea</a>.<br /> If there is a genuine update to be made, please contact us and request that the post is reopened.
AliAtSafe
Forum|alt.badge.img+23
  • March 31, 2025
Hi, ​@crutledge.
crutledge
  • April 8, 2025
Thanks for the reply ​@AliAtSafe All good points. I think in my case it was data issues.
