Over Looping polygons
  • September 21, 2022
  • 25 views
Forum|alt.badge.img+5
I have Workspace where shapefile has polygons they overlap so i want
they should be no overlapping . lowest values are normally on outside so I start clip with the next highest values then you move from low to high
geomancer
Forum|alt.badge.img+60
Looping should not be necessary. You can use an AreaOnAreaOverlayer, writing the Value attribute to a list, a ListSorter to ensure list element 0 contains the lowest (or highest) value, a ListIndexer to write the value of element 0 back to the Value attribute, and a Dissolver to merge the polygons on the Value attribute.
Something like the solution to this question.
I am new if you dont mind can you help me out to create the workspace form e
geomancer
The best way to learn FME is to try it for yourself.
The workspace in the question I linked to should give you something to start with.
Thanks for your helpp
