FME server password policy?
  • Sep 6, 2017 2:40 AM UTC
  • 89 views
Is it possible to enforce the minimum password length for FME server from application?
If yes, what is password policy and how to enforce?
Best answer by david_r
As far as I know, this isn't possible using the built-in FME Server authentication.
If you use an external authentication system, e.g. Active Directory, you should look into implementing the policies there.
  • Sep 6, 2017 7:22 AM UTC
Thanks David!
do you know, what is default FME server minimum password length?
  • Sep 6, 2017 7:52 AM UTC
Thanks David!
It's 1 character. The only restriction seems that you cannot leave the password blank.
