FME-Server: CORS-Error
  • Nov 20, 2018 1:43 PM UTC
  • 207 views
gpt_geoinfo
Forum|alt.badge.img+3
Hey guys,
Why do I get the error (some texts replaced for security reasons):
Failed to load http://fme-serverdomain.com/fmedatadownload/repository/workspace.fmw?param1=somefile&param2=sometext&opt_responseformat=json&token=123456789&detail=high: Response to preflight request doesn't pass access control check: No 'Access-Control-Allow-Origin' header is present on the requested resource. Origin 'http://someotherdomain.com' is therefore not allowed access.
although I configured CORS to allow all hosts
itsmatt
Forum|alt.badge.img+48
  • Nov 20, 2018 2:55 PM UTC
I think in this case it's referring to the specific header 'Access-Control-Allow-Origin' add that into the list of allowed headers and try again
gpt_geoinfo
  • Nov 21, 2018 7:41 AM UTC
Unfortunately this didn't help
laurawatsafe
Forum|alt.badge.img+14
Hi @gpt_executer,
How are you making the call to your FME Server when you're seeing this error? Are you attempting to open the URL to the datadownload service directly in a web browser or are you sending the request from another application? If you're running this from another application, would you be able to share an example of the code you're using to make the call?
runneals
Forum|alt.badge.img+32
  • Feb 13, 2025 5:43 PM UTC
I think I’m running into this issue as well.
