PythonCaller: download from FTP to specific folder
  • October 30, 2024
  • 4 replies
  • 86 views
fikusas
How can I download file from ftpes:// to specified folder? I’m using the script below.
import fmeobjects
import os
from ftplib import FTP_TLS
import ssl
def processFeature(feature):
    path = '/lsms/'
    filename = 'apples.zip'
    ftp = FTP_TLS('FTP-SERVER')
    ftp.ssl_version = ssl.PROTOCOL_TLS
    ftp.login('name', 'pass')
    ftp.prot_p()
    ftp.cwd(path)
    ftp.retrbinary("RETR " + filename, open(filename, 'wb').write)
    ftp.quit()
    feature.setAttribute('name', filename)
david_r
  • October 30, 2024
Why not use the FTPCaller?
fikusas
  • October 30, 2024
FTPCaller gives error with no clear info about it. I'm using older version of FME. Trying to work around this.
saraatsafe
  • November 6, 2024
Hi @fikusas, what’s the error you’re running into when you try the FTPCaller? It might help to run your workspace with Log Debug enabled, sometimes that can give us a little more information as to what’s gone wrong. You can enable Log Debug by navigating to Tools > FME Options > Translation > Log Settings.
fikusas
  • November 7, 2024
Log shows “Error” without any details about it. Probably its version bug.
