Why does FME now takes 5 minutes to 'select ArcObjects licence from the registry'?
  • Dec 4, 2017 3:53 PM UTC
  • 51 views
iew
SInce upragding to ArcGIS 10.5.1 it is taking over 5 minutes to simply add a geodatabase reader to a workspace. I am using FME 32bit 2017.1.1.1. As you can imagine this renders this combination practically unusable. Things were fine previously.
fmelizard
Forum|alt.badge.img+22
  • Dec 6, 2017 7:50 PM UTC
Hi @iew,
Is this still causing you problems? If so you may want to report a problem here so that we can better address.
For anyone else experiencing this please comment below - thanks in advance
