When loading MasterMap can I choose identical schema?
Best answer by ian_mitchell
a bit more info for this one ... I'm running a process which reads a set of OS MasterMap topo GZ files extracts some specific Topo Areas and writes them to TAB
just a question about the Reader ... can I tick the box that says "Identical Schema"? ... is it worth doing? does it make a difference to speed (or anything else) or how does it change the processing?
many thanks
IanM
<strong>This post is closed to further activity.</strong><br />
It may be a question with a best answer, an implemented idea, or just a post needing no comment.<br />
If you have a follow-up or related question, please <a href="https://community.safe.com/topic/new">post a new question or idea</a>.<br />
