Query ArcGIS feature service by using bounding box in where clause
  • Jul 17, 2023 10:03 AM UTC
  • 183 views
lhcamm
I am trying to put query where clause in feature reader. the reader data is from esri Portal Feature Serice. I would like to put bounding envelop into where clause. I am not sure what is the clause should be. I would not like to query them all then do intersect. i would only like to query everything in the box I defined.
the clause i am using somehting like:geometryType=esriGeometryEnvelope&geometry=1.6407885025300004E7,-4272238.302200001,1.6703666006300002E7,-4088621.626699999. it didn't work
image.pngI would like to know:
  1. where clause support extent clasue
  2. if so what is the correct the clause structure.
Thank you very much.
hkingsbury
Forum|alt.badge.img+73
  • Jul 17, 2023 8:11 PM UTC
The WHERE clause is basically a simple SQL attribute WHERE statement e.g.
name="Hamish" and ID=1234
What you want to use is the Spatial Filter. This works by have a geometry on your initiator feature then setting the Spatial Filter attribute in the feature reader. You'd use your bounding box to create a geometry before the FeatureReader and then the set the FeatureReader to have the Spatial Filter you're after
