Python Exception ImportError fme-form-2023.2.1
  • Mar 11, 2024 9:14 AM UTC
  • 402 views
ciarab
Forum|alt.badge.img+10
Some users in my organisation are getting the below error when using  using fme-form-2023.2.1-b23774-win-x64.
They have already looked at editing the path in environment variables and that didn't work. Any suggestions on a solution?
Python Exception <ImportError>: This package should not be accessible on Python 3. Either you are trying to run from the python-future src folder or your installation of python-future is corrupted.
Failed to import `fmesite'
Failed to import `fme'
(PythonFactory): The Python Framework could not be started. PythonFactory could not initialize
ali-safe
Forum|alt.badge.img+24
  • Mar 12, 2024 9:51 PM UTC
Hi, @ciarab.
It seems, as you suggested, it is due to the Environment Path variables potentially not being set correctly. I would suggest to double-check to make certain that PATH, PYTHONPATH, PYTHONHOME, etc. are set properly; checking the output of the PATH variable too.
Additionally, do you know where the error is being produced (e.g., running the Python script in FME Form via the PythonCaller/Python startup script)?
Best,
