Python - Even or Odd
  • Aug 31, 2016 2:19 PM UTC
  • 81 views
danilo_fme
Forum|alt.badge.img+58
Hello Users,
Attached the Workspace with the transformer PythonCaller. This transformer receive the attributes from Souce Data ( list values ) and generate two new Attributes to each list value : initial and final. This is Works fine.
So now i need to create 4 news attributes to each list values: Initial_even, End_even, Initial_odd and End_odd. For example to list 1: Inicial: 0 Final: 40 How it be: Initial_even:0 End_even: ( Initial_even.list1{} + attribute lenght this list ( int(listaTamanhoTrecho[controle] )) = 40 Initial_odd: ( Initial_even.list1{} + 1 ) = 1 End_odd: ( End_even.list1{} + 1 ) = 41
To list 2 Initial_even: ( End_even.list1{} + 2 ) = 42 End_even: ( Initial_even.list2{} + attribute lenght this list ( int(listaTamanhoTrecho[controle] )) = 126 Initial_odd: ( Initial_even.list2{} + 1 ) = 43 End_even: ( End_even.list2{} + 1 ) = 127
To list 3 Initial_even: ( End_even.list2{} + 2 ) = 128 End_even: ( Initial_even.list3{} + attribute lenght this list ( int(listaTamanhoTrecho[controle] )) = 255 *** How this value is odd, is necessary to transform to even value: +1 = 256 Initial_odd: ( Initial_even.list3{} + 1 ) = 129 End_odd: ( End_even.list3{} + 1) = 257
Thanks
Best answer by takashi
Hi @danilo_inovacao, sorry I'm completely unclear the requirement. What are the 'list 1', 'initial_even.list1{}', 'End_even.list1{}', etc. in your description? Does the 'attribute length' mean the number of characters of the attribute value?
If you are just looking for a way to determine if an integer is even or odd, divide the number by 2 and then see if the reminder is 0 or 1. The % operator is helpful.
  • Aug 31, 2016 10:29 PM UTC
mark2atsafe
Forum|alt.badge.img+59
There's even a ParityFilter on the FME Store that will test for odd/even values of integers.
