Python creator "outdated package" error
  • Nov 26, 2024 5:10 AM UTC
  • 102 views
poonam21
Forum|alt.badge.img+8
Hi folks,
I’m trying to execute a python script using Python Creator. The flow is running as expected also with expected outcome, but its giving this error -
I have checked the updates is FME package but still not working.
Not getting why this error is occuring.
If anyone has any idea about it, kindly help.
Thanks in advance.
Best answer by ebygomm
I’ve seen that message where the Class to Process Features entry doesn’t match what’s in the code window.
It doesn’t look like the code you are using is set up correctly for a pythoncreator, you would need something like this
import shutil
import os
from datetime import datetime
def FeatureCreator(feature):
<code here>
  • Nov 26, 2024 8:27 AM UTC
Can you share a print screen of your PythonCreator, and perhaps also the code.
poonam21
  • Nov 26, 2024 8:41 AM UTC
Below is the python script.
Forum|alt.badge.img+54
  • Nov 26, 2024 8:54 AM UTC
import shutil
import os
<code here>
poonam21
  • Nov 26, 2024 9:38 AM UTC
Hey ​@ebygomm Got that!!
I was not using class in python script.
Thankyou so much.
