python caller save problem
  • May 24, 2018 7:45 AM UTC
  • 7 replies
  • 91 views
Sometimes and non-reproducible changes I have done in source code are not saved.
Mostly it works but in estimated 5% my changes are lost.
If I change text I always type ctrl-s, mostly two or three times. If the changes are big I type spaces and save again. I reenter the source code and look for my changes.
BUT whatever I do, sometimes FME "forgets" my changes, today it forgot it, even when I ran the translation (in the control before my changes were made).
Has anybody else such problems? Is there a "correct" way to save the sources or a workaround for it?
I actually use the version 2016.0 (in former versions the problem was the same)
Hope, anybody can help
  • May 24, 2018 7:55 AM UTC
I use the PythonCaller a lot, but I've never encountered this issue.
  • May 24, 2018 9:29 AM UTC
Can you explain, what exactly you do to save?
  • May 24, 2018 9:31 AM UTC
I click Ok to close the Python editor and then Ctrl-S to save the workspace, mostly. Nothing special at all.
  • May 24, 2018 9:44 AM UTC
I recon that you have closed the python caller by the top right X close button which does not save the changes you have done. As I have done that a few times and in other transformers too.
  • May 24, 2018 10:40 AM UTC
no, sorry. if it had been so easy I would not have asked ... Always "OK"- Button
  • May 24, 2018 11:05 AM UTC
It probably sounds as if I was a beginner. But it is not and I know, that I must use "OK", save and so on. But from time to time I loose source code and do not know, how this might happen ...
christian_dan
Forum|alt.badge.img+3
I have also recently observed this occurrence in FME 2024.1 (Build 24619).
