pseudonode in line network
  • Apr 7, 2017 5:22 AM UTC
  • 13 replies
  • 198 views
gis2020
Forum|alt.badge.img+5
Hi All,
I am working on the line network wherein i want to find the pseudonodes. can somebody help me with this.
Thank you in advance !!
Best answer by david_r
Using the TopologyBuilder to find nodes that are connected to only two edges:
itay
Forum|alt.badge.img+19
  • Apr 7, 2017 6:09 AM UTC
If you mean the start/end vertices you can try the TopologyBuilder, the Node port will provide you with all the start/end vertices of your data.
If you need ALL of the vertices use a chopper set to 1
hope this helps.
  • Apr 7, 2017 6:22 AM UTC
Hi @dandekarpriya, I'm not sure what "pseudo node" means correctly. If you define that "pseudo node" is "a node connecting only two edges", you can determine if a node is a pseudo node based on the number of elements of the _node_angle{} list added to the nodes which are output via the Node port of a TopologyBuilder.
  • Apr 7, 2017 7:51 AM UTC
My interpretation of what @dandekarpriya means by pseudo node given that he mentioned network:
Do you have the network links and nodes geometries and want to identify where a node is related to only two links?
If so PointOnLineOverlayer creates an Overlap Count Attribute on both links and nodes. If this value equals 2 on the nodes it is by my definition a pseudo node. Test the nodes for this value equals 2. This assumes a clean network where the node geometry equal the end of the link.
gis2020
  • Apr 7, 2017 9:18 AM UTC
Hi Takashi ,
pseudonode is nothing but a node which Appears along a continuous line and divides it unnecessarily or where a single line connects with itself or where only two Polylines intersect.
gis2020
  • Apr 7, 2017 9:19 AM UTC
hi @mark_1spatial
i have a line network where i want to identify the pseudo nodes.
gis2020
  • Apr 7, 2017 9:22 AM UTC
hope this helps.
thank you itay. i have used this for finding the dangles and overshoots could you please explain it in detailed how this can be used for finding the pseudonodes
  • Apr 7, 2017 9:35 AM UTC
Hi Takashi ,
That is, the necessary and sufficient condition for a node being a pseudonode is, the number of connections at the node is just two. Isn't it?
itay
  • Apr 7, 2017 9:40 AM UTC
If your definition is the same as @mark_1spatial then the method proposed should do the trick.
  • Apr 7, 2017 9:43 AM UTC
gis2020
  • Apr 10, 2017 7:44 AM UTC
yes that's right . i have tried to use to use the node angles and it work fine. Thank you takashi
gis2020
  • Apr 10, 2017 7:45 AM UTC
Thank you david i have tried the same with little modifications and it worked fine.
Thanks again :)
gis2020
  • Apr 10, 2017 8:08 AM UTC
how i can get information of associated edges to each node. i mean the arc_id?
  • Apr 15, 2017 8:54 AM UTC
The absolute value of an element of the _node_angle{}.fme_arc_id indicates the _edge_id of a connected edge. The sign of each element indicates the direction of the edge relative to the node. i.e. positive indicates that the edge connects to the node at starting point; negative indicates that the edge connects to the node at ending point. Everything is described by the help on the TopologyBuilder.
