Log request
dustin
Forum|alt.badge.img+31
I do realize it's possible using the startup script, but it would be nice to have the time/date recorded at the beginning of the log when a translation is started.  If a user wanted to know during a translation when it was began, they would have it in the log.  Maybe it's there, and I'm overlooking it?
  • April 23, 2013
you can enable this under the menu Tools / FME Options / Runtime.
Check the box "Log timestamp information". This will echo the timestamps from the log file in the Workbench log window.
David
dustin
  • April 23, 2013
I was just coming back to say I found it.  Thank you.
