I’m trying to use the mgrs library in FME, but the following error is shown:
mgrs
Message Type: fme::internal::_v0::py::ExceptionPython Exception: <ModuleNotFoundError>: No module named 'mgrs'
If I run it in a standalone script, it works very well. The library has been successfully installed on my machine.
Thank you.
Best answer by hkingsbury
how have you installed it and what python is your workspace set to use? (FME or ArcGIS)
If you’re using the FME defualt python, make sure you installed it using:
fme.exe python -m pip install <package_name>
from https://docs.safe.com/fme/html/FME-Form-Documentation/FME-Form/Workbench/Installing-Python-Packages.htm
I´m set to use FME. Thank´s
17 votes
15 votes
12 votes
9 votes
8 votes
7 votes
6 votes
5 votes
Already have an account? Login
Sorry, we're still checking this file's contents to make sure it's safe to download. Please try again in a few minutes.
Sorry, our virus scanner detected that this file isn't safe to download.
We use 3 different kinds of cookies. You can choose which cookies you want to accept. We need basic cookies to make this site work, therefore these are the minimum you can select. Learn more about our cookies.
