Issue with writing lines to 10.4 Geo-database on SQL server using MS SQL Server Spatial writer
  • Sep 19, 2018 4:47 PM UTC
  • 180 views
Hi There, I am reading data from a 10.4 Geodatabase (on SQL server) using Microsoft SQL Server Spatial writer. I am also writing this data to 10.4 Geodatabase (on SQL server) using MS SQL Server spatial writer. The update process runs fine but when I open the features in ESRI ArcGIS, I get this error. I noticed that it happens only with lines, point datasets work fine.
Underlying DBMS error [[Microsoft][ODBC Driver 13 for SQL Server][SQL Server]A .NET Framework error occurred during execution of user-defined routine or aggregate "geometry":
System.ArgumentException: 24144: This operation cannot be completed because the instance is not valid. Use MakeValid to convert the instance to a valid instance. Note that MakeValid may cause the points of a geometry instance to shift slightly.
andreaatsafe
Forum|alt.badge.img+17
Hi @jayd3vl,
Could you try using the ArcSDE Geodb writer instead of the Microsoft SQL Server Spatial Writer?
stalknecht
Forum|alt.badge.img+22
  • Sep 23, 2018 2:38 PM UTC
Please try the ArcSDE reader and writer. An Arcgis Geodatabase is better handled by the SDE. If you use the backdoor using a SQL Server reader/writer you will get funny results. These readers and writers are not aware of by example versioning that the SDE does.
  • Sep 25, 2018 3:16 PM UTC
Thanks stalknecht, Andrea for your feedback. The reason for using SQL Server Spatial wrier was the support for bulk Insert. Our business requirement is that in case of failed process, the original data remains intact. ESRI Geodatabase writer has this property “Features to write per transaction” and I set it to a very high value. I came across a scenario where there was an error with the workspace and rollback didn’t happen. I noticed that this writer writes record by record.
I would prefer to use ESRI geodatabase writer if I can get the rollback functionality to work. I am curious if anyone else had success with rollback using ESRI geodatabase writer. Thanks jay
stalknecht
  • Sep 26, 2018 3:39 PM UTC
What transaction-type do you use? I think it should be Transactions. See a screenshot from the help:
