(Integer) values of constants in Python API FME
  • Oct 20, 2023 10:19 AM UTC
  • 193 views
ronaldhummelink
Forum|alt.badge.img+9
Today I was helping one of the users in my organisation with some code in a PythonCaller.
The value returned by fmeobjects.FMEFeature.getAttributeType — Python FME API FME 2023.0 b23309 documentation (safe.com) is an integer.
The list of possible values is defined by the list of constants here Features — Python FME API FME 2023.0 b23309 documentation (safe.com)
What I am missing is which constant represents which integer value.
Are these available somewhere?
This would have been helpful understanding me and my user what was happening.
Best answer by david_r
Agree this is the right way when you want to perform different actions based on the data type, you should always compare to the defined constants, not their values.
My case was diagnostic, so knowing which constant the values represent (even if just in the context of the FME version) is very useful.
I usually won't know the data model my users are working with; and they are not software developers (Which is my background)
You could always use some introspection to iterate over and print the values to the FME log from a PythonCaller, e.g.
import fmeobjects
def ListFmeDataTypeConsts(feature):
    contents = dir(fmeobjects)
    for obj in contents:
        if obj.startswith('FME_ATTR'):
            print('{} = {}'.format(obj, getattr(fmeobjects, obj)))
Output:
FME_ATTR_BOOLEAN = 1
FME_ATTR_ENCODED_STRING = 12
FME_ATTR_INT16 = 4
FME_ATTR_INT32 = 6
FME_ATTR_INT64 = 13
FME_ATTR_INT8 = 2
FME_ATTR_LIST = 4
FME_ATTR_REAL32 = 8
FME_ATTR_REAL64 = 9
FME_ATTR_REAL80 = 10
FME_ATTR_STRING = 11
FME_ATTR_UINT16 = 5
FME_ATTR_UINT32 = 7
FME_ATTR_UINT64 = 14
FME_ATTR_UINT8 = 3
FME_ATTR_UNDEFINED = 0
  • Oct 20, 2023 10:28 AM UTC
The utility of the constants is to avoid having to know the actual internal value, since it might potentially change between releases. Best practice would be to simply compare the returned value with the constants, e.g.
attr_type = feature.getAttributeType('my_attribute')
if attr_type == fmeobjects.FME_ATTR_STRING:
    # it's a string
elif attr_type == fmeobjects.FME_ATTR_INT64:
     # it's a 64-bit integer (bigint)
 That way your code automatically adapts even if, for some reason, the internal integer values associated with the constants should change.
ronaldhummelink
    # it's a string
  • Oct 20, 2023 12:25 PM UTC
import fmeobjects
Output:
FME_ATTR_INT16 = 4
FME_ATTR_INT32 = 6
FME_ATTR_INT64 = 13
FME_ATTR_INT8 = 2
FME_ATTR_LIST = 4
FME_ATTR_REAL32 = 8
FME_ATTR_REAL64 = 9
FME_ATTR_UINT16 = 5
FME_ATTR_UINT32 = 7
FME_ATTR_UINT8 = 3
ronaldhummelink
Thank you, and a valuable bit of insight into Python possibilities too (My background is (/used to be) PHP and C# web application development)
