igds_element_visibility
  • Oct 2, 2014 10:18 AM UTC
  • 0 replies
  • 31 views
The following is stated regarding the dgn attribute igds_element_visibility:
This attribute has the value yes if the level the element is on has its display property set to “on”; otherwise, the value is no.
My question is where is this display property?  I can't find that anywhere!  Also, is it possible to set the global display property of a dgn level in a writer, certainly the igds_element_visibility only appears in the reader.
Many thanks
Dan
