I have a PythonCaller that worked in FME 2017, when I migrated to FME 2019 it is erroring
This is the error I receive from the PythonCaller:
Python Exception <ValueError>: 'L' is not in list
Traceback (most recent call last):
File "<string>", line 22, in input
ValueError: 'L' is not in list
Error encountered while calling method `input'
PythonCaller_3 (PythonFactory): PythonFactory failed to process feature
Here is the python in the PythonCaller: it's reading two attributes from the ListBuilder. This runs on the same data without error in FME 2017
# Template Class Interface:
# When using this class, make sure its name is set as the value of
# the 'Class or Function to Process Features' transformer parameter
class FeatureProcessor(object):
def __init__(self):
pass
def input(self,feature):
self.listC = feature.getAttribute('_list{}.c')
self.listL = feature.getAttribute('_list{}.l')
self.list = zip(self.listC,self.listL)
if self.list != None:
self.check = []
for i,e in enumerate(self.list):
if e[1] == 'M':
self.check.append(e[0])
if not self.check:
self.add = []
self.add.append(e[1])
val = self.add.index('L') + 1
x = i + 1
if x == val:
feature.setAttribute('_list{%d}.l' %i,'M')
self.pyoutput(feature)
def close(self):
pass
Best answer by ebygomm
My guess would be that you've changed from Python 2.7 to 3.x and your script needs to be updated to run
e.g. zipping a list has definitely changed between the two so this line
would become this
self.list = list(zip(self.listC,self.listL))
There may be other changes required also, it's hard to tell without the code formatting and the source data
Forum|alt.badge.img+39
  • May 4, 2020
Can you post the python code as code
  • May 4, 2020
Did you perhaps change from Python 2.7 to 3.x? The two versions aren't fully compatible.
Also, are you 100% sure that the input data is identical between the two FME versions?
  • May 4, 2020
would become this
  • May 4, 2020
The above post was correct -- It was the zipping. thank you so much for your help!
  • May 4, 2020
would become this
Thank you!  That was the issue!!! I
