I am trying to use HTTPCaller to generate a token which can be used in a REST API Service. The token can be generated manually from the web site: https://gisservices.information.qld.gov.au/ArcGIS/tokens/generateToken. I am putting the parameters for this into the 'Query String Parameters box'. I just need an example of how this is done using the HTTPCaller? I keep getting 'HTTP Method Not Allowed'
Best answer by johnm
Hi @itay, Thankyou very much for this. That worked perfectly on the desktop. I will apply this to FME Server as well. Just a quick question, can you explain the 'Content Type:
application/x-www-form-urlencoded and how it is derived? Thanks again, John
Rich Text Editor, editor1
Editor toolbars
Press ALT 0 for help
