I am trying to use HTTPCaller to generate a token which can be used in a REST API Service.
  • Mar 24, 2017 2:04 PM UTC
  • 8 replies
  • 324 views
I am trying to use HTTPCaller to generate a token which can be used in a REST API Service. The token can be generated manually from the web site: https://gisservices.information.qld.gov.au/ArcGIS/tokens/generateToken. I am putting the parameters for this into the 'Query String Parameters box'. I just need an example of how this is done using the HTTPCaller? I keep getting 'HTTP Method Not Allowed'
Best answer by johnm
Hi @itay, Thankyou very much for this. That worked perfectly on the desktop. I will apply this to FME Server as well. Just a quick question, can you explain the 'Content Type:
application/x-www-form-urlencoded and how it is derived? Thanks again, John
  • Mar 24, 2017 2:58 PM UTC
Seems you have to use POST over an https connection, unless they have specifically activated GET. Documentation: http://resources.arcgis.com/en/help/arcgis-rest-api/index.html#//02r3000000ts000000
  • Mar 25, 2017 10:21 AM UTC
Thanks David, I have changed to a POST but I am still not getting a token back: {"error":{"code":201,"message":"Exception in generating token","details":"Invalid request <br>Usage: https://gisservices.information.qld.gov.au/arcgis/tokens?request=gettoken&username;=username&password;=password&<br>Usage: https://gisservices.information.qld.gov.au/arcgis/tokens/generateToken?username=username&password;=password
I am just not sure what values should be in the HTTPCaller httpcaller.pdf
  • Mar 25, 2017 10:30 AM UTC
@itay Hi , Can you please provide your example Workspace again:
downloadws2015v2.fmw
I can't seem to retrieve it?
itay
Forum|alt.badge.img+19
  • Mar 25, 2017 1:54 PM UTC
Hi @johnm, I am adding a template I use for requesting a token from FME SERVER, hopefully it can be of help to you how to configure the request.
Made with FME 2017
requesttoken.fmw
itay
Made with FME 2017
requesttoken.fmw
  • Mar 26, 2017 1:50 AM UTC
itay
  • Mar 26, 2017 7:10 AM UTC
See more about content types here:
http://playground.fmeserver.com/using-the-rest-api/basics/
I have converted my previous comment to an answer.
  • Mar 27, 2017 7:08 AM UTC
You probably have to transmit the parameters in the message body and not in the URL.
