How to transform a polygon shape of text to text ?
  • Mar 11, 2021 9:10 AM UTC
  • 6 replies
  • 214 views
polygonTextHello ! Does anybody have a clue how to transform a polygon reprensenting a text to a text ? See attached image.
Best answer by david_r
Hi David !
I've got a rejection message :
Teeseract didn't find any text on this raster
Is there a problem with my parameters ? see attached imageserror messageParameters
I've never used the TesseractCaller myself, but perhaps you can find some pointers either in the documentation, or in this article: https://www.safe.com/blog/2016/10/ocr-for-fme-now-i-know-my-abc/
  • Mar 11, 2021 9:16 AM UTC
One possibility is to rasterize (e.g. using the ImageRasterizer) the polygons and using the TesseractCaller to do OCR on the result. When rasterizeing, you may want to make sure the polygons are filled, not just outlined.
  • Mar 11, 2021 9:45 AM UTC
Hi David !
  • Mar 11, 2021 10:15 AM UTC
Hi David !
  • Mar 11, 2021 10:20 AM UTC
Hi David !
Ok.
Thank you very much ! I think the TesseractCaller is the solution to my problem. I'll read the documentation to see about the parameters.
Thanks again and have a nice day !
  • Mar 11, 2021 7:08 PM UTC
An alternative solution would be to use the RekognitionConnector with action "Text detection". It will use AWS to perform text detection, and in my experience it is really, really good.
The service might be billed depending on the number of requests, although I find it very reasonable for the quality it offers.
a.bradley
Forum|alt.badge.img+12
Hi David !
Ok.
​@sam.27 did this solution work for you? I am also getting a rejection message and have the exact same task as you with the area/polygon numbers needing to be converted to text.
