How to join a fieldname lookup
arnold_bijlsma
Forum|alt.badge.img+14
I've got a list of sewer subcatchments with an ID field and 12 numeric columns called area_absolute_1 to area_absolute_12. But only some of those 12 are used; the other columns are all zeroes.
subcatchment_number	area_absolute_1	area_absolute_2	area_absolute_3	area_absolute_4	area_absolute_5	area_absolute_6	area_absolute_7	area_absolute_8	area_absolute_9	area_absolute_10	area_absolute_11	area_absolute_12
1	0.439	0.277	0	0	0	0	0	0	0.054	1.54	0	0
2	0	0	0	0	0	0	0	0	0	0	0	0
3	0	0	0	0	0	0	0	0	0	0	0	0
4	0	0	0	0	0	0	0	0	0	0	0	0
5	0	0	0	0	0	0	0	0	0	0	0	0
6	0.228	0.334	0	0	0	0	0	0	0.026	0.172	0	0
I also have a small lookup table that tells me which columns are in use, and what these columns represent:
Surface Number	Surface Type
Surface 1	Road
Surface 2	Roof
Surface 3	-
Surface 4	-
Surface 5	-
Surface 6	-
Surface 7	-
Surface 8	-
Surface 9	Road
Surface 10	Permeable
Surface 11	-
Surface 12	-
The last column can only have values "Road", "Roof" or "Permeable"; but each of these can exist more than once (the maximum I have seen is three).
I now need to know the total area of roads, roofs, and permeable area in each subcatchment. For roads, it would be summing columns "area_absolute_1" and "area_absolute_9"; for roofs, just column "area_absolute_2", and for permeable, just column "area_absolute_10".
How do I join the fieldname lookup table to the data table, so that I can calculate the totals for each of the three surface types?
I need to do this hundreds of times. The datasets always have those same 12 columns, but the surface type mapping varies. Therefore I can't do any hard-coding of column names.
Attached is template which kind of works, but it seems an onerous way to go about it, and I feel there must be a simpler, more elegant way?
SurfaceMapping
Best answer by nielsgerrits
I would use an AttributeExploder to explode the data into features, merge the lookup table and rebuild the data using an AttributeCreator and an Aggregator. Workspace attached.
nielsgerrits
Forum|alt.badge.img+58
  • June 11, 2021
arnold_bijlsma
Dankjewel @nielsgerrits​. That's perfect: it's much neater and tidier than my initial attempt. And also takes care of the scenario when there are more than 3 surface types mapped as "Road" (which initially I thought wasn't possible!)
