How to get Notifications working with REST API
  • Feb 24, 2015 1:41 PM UTC
  • 0 replies
  • 15 views
sigtill
Forum|alt.badge.img+25
Using this REST-call
http://fmeserver/fmerest/v2/transformations/commands/submit/Samples/austinDownload.fmw?detail=high
With these parameters
{ "FMEDirectives": {}, "NMDirectives": { "failureTopics": [], "successTopics": [] }, "TMDirectives": { "rtc": false, "ttl": 120, "description": "This is my description", "priority": 5, "tag": "linux" }, "publishedParameters": [ { "name": "MAXY", "value": "42" }, { "name": "THEMES", "value": [ "airports", "cenart" ] } ], "subsection": "REST_SERVICE" }
And adding the services to notify:
    "NMDirectives": {
        "successTopics": [
            "MYTOPIC_OK"
        "failureTopics": [
            "MYTOPIC_CALLED"
and even trying to set it "manually"
    "FMEDirectives": {
        "TEXTLINE_1_DATASET": "!FME_AUTO_DIR_NAME!_nw\\\\textline.txt"
It does not seem to be able to write a textfile to send to the notification.
Any help from Safe or users regarding this?
I would expect it to be able to send the text_line_data to the notification - however it seems the output-directory/file for the TEXTFILE writer does not get set when using the RESTAPI and no file is created. When you use the JOBSUBMITTER it works as expected and the text_line_data is generated properly.
