How to add TOKEN within a HTTPCaller RESTful API request?
  • Oct 18, 2018 2:03 PM UTC
  • 626 views
juanmahere
Forum|alt.badge.img+15
Hi guys,
I've tried to find any related question from this one, and no luck, so here is my doubt:
I want to use HTTPCaller to send a GET, POST, UPDATE,... request to this RESTful API:
API
So, authenticating the request is necessary and I'm not well related to the transformer HTTPCaller, so, I'm not sure if there is any particular option/way to insert the Token within the requests. Should be put the Token value within a the Header? I'm totally lost.
If I plainly send the request
, throws me back a http error:
HTTP/1.1 401 Unauthorized - https://xyz.api.here.com/hub/spaces?includeRights=false&owner;=me
Could you give any hint?
Thanks in advance,
Best answer by jlutherthomas
Hi @juanmahere
It looks like in a different section of the API documentation they discuss how to authorize the REST calls. You can view that here.
If you have your token, you can input it into the HTTPCaller as a header like this:
Authorization: Bearer <token>
or alternatively, as a URI query parameter:
access_token=<token>
Hi @juanmahere
juanmahere
  • Oct 18, 2018 2:32 PM UTC
Hi @juanmahere
Thanks a lot! How I missed that part on documentation... Oh my god...
It served, I've put as indicated and works (got me a 200 response):
