How can I use the HTTPCaller to get data from SPLUNK RES API
fbrws
BANNED
I am able to use Powershell to get json data from SPLUNK Res API.
Now I want to translate this method to the HTTPCaller, but I dont succeed to get this working in FME. Does anybody have experience with this or has some tips and tricks?
virtualcitymatt
Forum|alt.badge.img+39
Hmm, looks pretty ok from here. There should be a couple of attributes on the rejected feature which hopefully might give you some clues as to what's going wrong. Check out the _reponse_body and _response_code attributes
geomancer
Forum|alt.badge.img+50
  • August 8, 2023
Under Workspace Parameters > Translation change the parameter 'Rejected Feature Handling' to 'Continue Translation'. Then you can study the rejected feature to determine what went wrong.
fbrws
BANNED
  • BANNED
  • August 8, 2023
Good tip, thx!
fbrws
BANNED
  • BANNED
  • August 8, 2023
I'll do thx!
fbrws
BANNED
  • BANNED
  • August 10, 2023
Soluton is to use a GET instead of POST!
And use SPLUNK parameters in the Query String Parameters.
I have added an image of the HTTP caller with correct layout.
