How can I start automating in FME form
  • Dec 28, 2024 4:47 AM UTC
  • 127 views
tamadur
i have daily & repeated work in geospatial data and I did it manually it takes a lot of time
Best answer by luke.hicks
Hi ​@tamadur,
Safe Software has an accompanying program called FME Flow which is what is used to automate jobs based on a variety of factors. If your organization has FME Flow you can publish your workspace to FME Flow from FME Form and start automating from there.
If you do not have access to FME Flow, options are quite limited. Users in the past have created batch files for Windows Task Schedule. With this, it is possible to create basic schedules for your workflows. Here is a past community post for instructions on how to perform this.
Hope this helps!
Cheers,
    - Luke H
luke.hicks
Forum|alt.badge.img+11
  • Dec 30, 2024 5:30 PM UTC
Hi ​@tamadur,
Hope this helps!
Cheers,
    - Luke H
