Run FME desktop automatically (scheduled)
  • Mar 21, 2018 11:50 AM UTC
  • 17 replies
  • 2034 views
Hi all,
I would like to run FME Desktop automatically. After seeing some posts, the only method that I have found is using FME Server, however, I have not understood how it exactly works. Could anyone please help? Is there any other way?
Many Thanks
Best answer by f.kemminje
for desktop ,
use bat file(normal text file)
batch file looks like this
c:\\fme\\fme.exe c:\\temp\\abc.fmw --publishedparameter1 --publishedparameter12
c:\\fme\\fme.exe c:\\temp\\abq.fmw --publishedparameter1 --publishedparameter12
fme.exe where your fme software is installed
fmw name : path and filename of your fmww file
--parameter names
then run this batch file from windows scheduler
And for fme server
upload your existing fmw to fme server
click on schedules
add new
type all the field like
name
fmw name
start run date
time
interval etc...
thats it . very easy
fme server will take care your job
danilo_fme
Forum|alt.badge.img+58
  • Mar 21, 2018 11:59 AM UTC
Hello @claraosuna,
There is a interesting video and Tutorial about this Schedule method:
https://knowledge.safe.com/articles/22724/schedule-a-workspace-to-run-with-fme-server.html
Thanks,
Danilo
stalknecht
Forum|alt.badge.img+22
  • Mar 21, 2018 12:44 PM UTC
You can also schedule a workspace with the windows scheduler. You don't need Server for that. Just copy the first lines of the logging and paste them in to a .bat or .cmd file. After each new line you have to paste the ^ character to tell windows that the next line is a parameter of the first line.
So if I take this example the command file would look like:
D:\\FME\\fme-desktop-2018.0-b18284-win-x64\\fme.exe C:\\Users\\stalknechtw\\Desktop\\demo.fmw^
--SourceDataset_ESRISHAPE "D:\\OneDrive\\DemoData\\GWB2016\\Uitvoer_shape\\gem_2016.shp"^
--DestDataset_PDF2D "C:\\Temp\\result.pdf"
this command file can be scheduled in the windows scheduler.
jneujens
  • Mar 21, 2018 1:14 PM UTC
How FME Server works?
You basically put your workspace on a server. Anyone with acces to that webpage can fill in the user parameters (the same as in workbench). It will then run the same process. You can get your output where you defined it or download it in a download package.
Major advantages: 1) you don't need FME Workbench on your machine to run data translations. 2) People who have no idea about FME/GIS can do transformations. 3) You could use windows scheduler, but if the number of processes increases it will get messy very quickly.
Without getting into technical details and the other possibilites, I think that sums up what FME Server is about.
f.kemminje
Forum|alt.badge.img+11
  • Mar 21, 2018 2:06 PM UTC
for desktop ,
--parameter names
And for fme server
click on schedules
add new
name
fmw name
start run date
time
interval etc...
  • Mar 23, 2018 12:13 PM UTC
Hi all (@danilo_fme @stalknecht @jneujens fkemminje)
Thank you very much for your help, it has been very useful. I already have created the schedule.
However, once I have completed this stage, I find another issue int he next one: is there any method to have the data recorded and keep adding the new one each time the workflow is refreshed?
Thank you very much indeed.
stalknecht
  • Mar 23, 2018 12:51 PM UTC
You have to configure the writer to prevent this. Which writer do you use?
  • Mar 23, 2018 1:00 PM UTC
.csv/xlsx
Is not possible to set it in the same workflow?
Thanks
  • Mar 23, 2018 1:04 PM UTC
for desktop ,
--parameter names
And for fme server
click on schedules
add new
name
fmw name
start run date
time
interval etc...
Just to add it is better for the BAT file to run a workbench which is just a Creator and workspaceRunner and if fails then Emailer.
Therefore you can catch the Main workbench's errors otherwise if it failed then the windows scheduler will say its competed with no error.
  • Mar 23, 2018 1:44 PM UTC
The purpose is calling an API and have recorded all the data that it is generating. There may be another way to automatically refresh the API instead running all the workflow
stalknecht
  • Mar 23, 2018 1:56 PM UTC
.csv/xlsx
Thanks
You can set the Overwrite Existing File to No
  • Mar 23, 2018 2:02 PM UTC
Great! It worked!
Many thanks!!
louisboekhoudt
I did this and it worked fine.
1st. Create a FME script, in my case, with FME 2022 workbench.
2nd. Run and break the tranalation.
3rd. Copy the lines between
"COMMAND-LINE TO RUN THIS WORKSPACE:" and "STARTING TRANSLATION".
4TH. Create/open a batch file and paste the copied line into it. Place place/copy/paste the character "^" at the end of each pasted lines and save the batch file.
6th. The batch file is ready to run. The running can be automated in the trigger tab in the TASK SCHEDULER app in windows microsoft.
fpaquet
Participant
  • Participant
  • Jan 19, 2024 6:06 PM UTC
Hello everyone,
I have an issue to execute my bat. files : I have a workspace without Reader. In that case, the bat. file just write "Emptying factory pipeline". I realised I don't have this issue when there's a Reader in my Workspace.
Is there someone who can help me with this ? :)
stalknecht
  • Jan 20, 2024 9:06 PM UTC
Hello everyone,
Can you share the .bat file and / or workspace ?
fpaquet
Participant
  • Participant
  • Jan 22, 2024 2:25 PM UTC
stalknecht
  • Jan 22, 2024 3:06 PM UTC
Looks like your batch file isn't passing the parameters correctly.
Now each line wil be executed by the command interpreter.
Enter an 'accent circonflexe' ^ after each line of code except the last line.
This will instruct the paramaters to be executed by the command as it's one line.
example:
"C:\Program Files\FME 2022\fme.exe" "bladibladibla.fmw"^
--DestDataset_FILECOPY_3 "$(FME_MF_DIR_USERTYPED) bladibladibla"^
--FME_LAUNCH_VIEWER_APP "YES"
sujitbhunia
Forum|alt.badge.img+3
  • Aug 21, 2024 1:11 PM UTC
Hi all,
Many Thanks
for desktop ,
--parameter names
And for fme server
click on schedules
add new
name
fmw name
start run date
time
interval etc...
Great. Thank you very much indeed.
