Having trouble adding a reader (ArcSDE Geodb).
  • Nov 21, 2023 7:31 PM UTC
  • 161 views
Adding an ArcSDE Geodb reader, FME Workbench 2019.1 throws: "GEODATABASE_SDE reader: An unknown exception occurred" followed by "Workspace generation failed. Parameter file was C:\\Users\\marsale\\AppData\\Local\\Temp\\FME_1700594969892_10740." It worked a couple months ago and my oracle account is fine (i can see and select the tables in Oracle, the error occurs when its trying to create the workspace).
stalknecht
Forum|alt.badge.img+22
  • Feb 21, 2024 10:12 PM UTC
Please update your FME software. Probably the version of FME is not compatible with the Arcgis version. Could be a compatability issue of Arcgis software versions and FME. Take a look at the following article: https://support.safe.com/s/article/notes-on-fme-and-esri-versions-and-compatibility
