From the attached image, I am running a workflow for QAQAC for 2nd Level Check of Electricity Data, and I discovered that some of the transformers is showing under Incomplete Transformers, and also I am having an error showing (ERROR_2.1B:
Wrong QA/QC Workflow
Kindly run data with the most recent workflow) based on the way the FME Administrator developed the workflow. My question is this, if a workflow is developed with older version of FME like 2 years Gap, does result to some Transformers been listed under Incomplete Transformers, and how can I resolve such Transformers.
