Getting Result values via REST with FME Server
  • Feb 8, 2019 3:05 PM UTC
  • 131 views
Hi there! I am currently taking the REST-Workshop, provided by safe.
Now i have quiet a simple task: I want to call a Workspace on FME Server via REST and in the Response there should be a certain value, that the Workspace created based on published parameters send with my request. I am working with Postman and basically you can imagine my needs like this:
I want to give two numbers via REST to a Workspace on FME Server, these two are added up and the sum will be send back in the Response. So it is synchronus, right?
My workspace already works, and i can start it with REST, but how do i get my stuff in a response without making another REST-Call?
Thank you very much for thinking about my problem!
  • Feb 11, 2019 8:40 AM UTC
It's not exactly the REST API, but you could use the fmedatastreaming service for this:
http://docs.safe.com/fme/html/FME_Server_Documentation/Content/ReferenceManual/service_datastreaming.htm
You could e.g. stream the results to a JSON writer.
  • Feb 11, 2019 8:46 AM UTC
Thats what i did now. And it works quiet well! But is there a way to use the actual REST API for this?
  • Feb 11, 2019 9:24 AM UTC
Unfortunately I don't think that's currently possible, although I'd be very glad if someone could prove me wrong.
