get FME server user information from REST end point?
  • Apr 10, 2016 8:36 PM UTC
  • 11 replies
  • 145 views
Hello, a newbie to FME server. Hope I can get some help here. Here are questions.
1. Where is the Security (users, groups, etc) info stored in the FME server directory?
2. Is it possible to get this info from the REST endpoint?
Thanks for your help,
Best answer by mark_f
Admin guide here:
http://docs.safe.com/fme/html/FME_Server_Documentation/Content/AdminGuide/Securing_FME_Server.htm
Have a look at the Security section under API
http://docs.safe.com/fme/html/FME_REST/v2/apidoc/index.html#
  • Apr 10, 2016 8:52 PM UTC
  • Apr 10, 2016 9:30 PM UTC
Mark, thanks for your quick response. Fantastic! I was able to retrieve account and role info from the links you provided. Thanks for your help. Alex
  • Apr 11, 2016 7:28 AM UTC
Just to supplement Mark's excellent reply: the security information isn't stored in the FME Server repository, but in the "fmeserver" database instance (Postgresql by default) notably in the tables fme_useraccount, fme_role, etc.
The REST API is definitely the best way to access it, however.
David
  • Apr 11, 2016 6:14 PM UTC
David
Thank David for the info. You are right. I couldn't find the security information from the server repository. I have installed a trial version of FME server, but didn't see a Postgresql instance is running. any ideas why?
  • Apr 11, 2016 6:30 PM UTC
Just want to extend my original question. how can I get custom info such as user activities (username, role type, no. of jobs run, etc)?
  • Apr 12, 2016 3:37 PM UTC
Look at the service called "FME Server Database", it is actually Postgresql in disguise, running on port 7082. You can connect e.g. using PgAdmin.
Both username and password = "fmeserver".
Be aware that unless you re-configure the instance you can only connect over localhost.
  • Apr 17, 2016 3:10 PM UTC
David
Thanks David. This is very useful info. I was able to connect to the instance and see how the info gets stored at behind. Good to know. Appreciate your response.
bjarne
Forum|alt.badge.img+5
  • May 11, 2021 8:58 AM UTC
hi,
is it possible to connect to fmecloud in this way (username=fmeserver?)
  • May 11, 2021 9:23 AM UTC
I believe it's possible, but I really wouldn't recommend it at all.
bjarne
  • May 11, 2021 11:13 AM UTC
ok, but how would you get  account and role info from fmecloud in a secure way?
  • May 11, 2021 11:52 AM UTC
I'm not sure I understand what you're trying to achieve...?
If you need a list of all the users and their roles, you should use the REST API:
https://docs.safe.com/fme/html/FME_REST/apidoc/v3/index.html
See e.g. the method
GET /security/accounts
 It will return a list of all the users and their associated roles, etc.
