GeoPDF layer hierarchy
rich_snyder
Participant
Does FME support writing a hierarchy of layers to GeoPDF? I can't find any documentation on how to do it.
hkingsbury
Forum|alt.badge.img+58
  • April 16, 2023
I would guess that the hierarchy is based on the order that the features are written. So to change the order, you will need to sort all your features before they're written
  • April 17, 2023
You can set the layer order on the feature type level, higher numbers are drawn later:
imageDocumentation: https://docs.safe.com/fme/html/FME_Desktop_Documentation/FME_ReadersWriters/pdf2d/feature-type-param-w.htm
You can also set the feature order within the same layer (feature type) by setting the format attribute "pdf_feature_order", see https://docs.safe.com/fme/html/FME_Desktop_Documentation/FME_ReadersWriters/pdf2d/Feature_Representation.htm
rich_snyder
Participant
  • Participant
  • April 17, 2023
My apologies for not providing enough information in the original question. When I use the word hierarchy I am referring not just to layer order, but to having multiple parent "folders" in the list of PDF layers.
I pulled the following image from a GIS Stack Exchange post with a similar issue:
na2JFRight now with FME all the layers I can create fall under a single "Layers" folder. I am curious if it is possible to create layers under multiple folders with different names - one parent folder for Landbase, one parent folder for Utilities, etc.
