Format or transformer to read prometheus metrics and convert into SQL Server
  • Nov 25, 2020 12:23 AM UTC
  • 133 views
rudy_v
Good Day
We have a few applications that expose prometheus metrics through an API, but there there no reader and or transformer to convert it to SQLServer.
Has anyone worked with prometheus metrics, and what is the best way to read prometheus metrics format in FME
or is just the best to use Prometheus and Grafana?
Rudy
rahulsharma
Forum|alt.badge.img+12
Hi @rudy_v​
Unfortunately, I have not worked with Prometheus Metrics.
Can you provide sample data?
You should be able to access the API using HttpCaller and process the response.
Is the response back is in JSON format? If yes, you can use the transformers such as JSONFragmentor, AttributeExposer to access geometry and attributes (and transform to SQLServer).
Some Articles that can be useful
https://community.safe.com/s/article/json-web-services-fme-uc-course
https://community.safe.com/s/article/json-transformations
