FME Server Error with REST API
  • Feb 17, 2020 11:11 PM UTC
  • 189 views
warrendev
Forum|alt.badge.img+28
I just started to receive this error on FME Server 2019.2 that won't allow me to view the jobs.
Here is the API response with the error below.
{"message":"org.dom4j.DocumentException: Error on line 1 of document  : An invalid XML character (Unicode: 0x7f) was found in the value of attribute "value" and element is "NM_DIRECTIVE". Nested exception: An invalid XML character (Unicode: 0x7f) was found in the value of attribute "value" and element is "NM_DIRECTIVE"."}
What can I do to diagnose what the issue is with the invalid character?
Also, I have only noticed this issue with transformations/jobs/completed API call, as the others are working correctly.
Best answer by warrendev
UPDATE:
No changes were made to the FME Server installation, repositories or workspaces, and now the error is not present. Not sure what was causing it, but everything seems to be working as expected now.
  • Feb 18, 2020 7:18 AM UTC
Try using the developer tools in your browser to inspect the network traffic between your browser and FME Server. An alternative might be to use something like Fiddler.
warrendev
  • Feb 18, 2020 3:23 PM UTC
Thanks @david_r, I've tried using Chrome dev tools as well as postman to perform the API calls, but can't seem to figure out where this invalid value is coming from. I have submitted a support ticket to SAFE.
warrendev
  • Feb 18, 2020 7:37 PM UTC
UPDATE:
