FME Fails to check overlapped hatches when transform them from AutoCad to ArcMap.
  • Apr 16, 2018 2:41 PM UTC
  • 58 views
alaa_flaifel
"FME Fails to check overlapped hatches when transform them from AutoCad to ArcMap."
FME transform overlapped hatches within the same layer from Autocad to ArcMap with no notification of double hatches. And this leads to defect in data when uploading them to our system.
What do you think about this?
Is there anyway to check double hatches in Autocad when Transforming?
Thanks!
Alaa
lars_de_vries
Forum|alt.badge.img+10
There are many solutions to this issue. I think the Matcher Transformer will help you most since you can use both attributes and geometry to check your features.
daveatsafe
Forum|alt.badge.img+24
  • Apr 16, 2018 4:07 PM UTC
Hi @alaa_flaifel,
I think the SpatialFilter is your best bet to find the overlapping Hatches. You can use the Group By option in the transformer to restrict the comparisons to within the same LayerName value, if you want.
alaa_flaifel
Thanks a lot!
Spatial filter (intersect Type) worked well with us.
Best,
Alaa
