FME bug causing failure in Workspace Runner, multiple datasets
jacklonsdale
Forum|alt.badge.img+4
Hi all,
Since upgrading to FME 2021, I have found previous workspaces that were working in 2020 are now not working. This appears to be when multiple datasets are referenced in a WorkspaceRunner and through a user parameter. It concatenates the filepaths together and loses the double quotes and separation, causing the reader to fail.
Any help would be appreciated.
Kind regards,
JackFME Problem 2FME Problem 1
rahulsharma
Forum|alt.badge.img+10
Hi @jacklonsdale​
There is one minor thing that I noticed in the WorkspaceRunner dialog, the Source Dataset is missing double quotes around the Filegeodatabase "$(FME_MF_DIR)Folder1\\Folder2\\Technical (T) - General\\Test\\*.gdb"
Can you try adding the quotes to see if that fixes the issue?
jacklonsdale
  • July 15, 2021
I've tried adding double quotes in the dialog and in text editor, but when I come out of the transformer settings, it removes them from the dialog! This is the weird thing...
cyril-fr
Participant
  • Participant
  • April 23, 2024
I have the same probleme with fme 2023.2.
I use WorkspaceRunner to call multiple postgis tables :
  • when I call the second workspace with fixed list of tables, it works
  • when the list of tables is written trough the editor or stored in an attribute, it fails
The log file reveals that fme try to read the entire string as a single table
I would appreciate some help
crystalatsafe
Forum|alt.badge.img+19
Hi @cyril-fr
If you are able to share both workspaces (one where it works and one where it doesn’t work) with us we can take a closer look.
Crystal
