FME and API
  • Mar 20, 2024 3:16 PM UTC
  • 135 views
fme_can_do_it
Forum|alt.badge.img+13
Hi, I am trying to make API requests to connect to an application. It requires OAuth1 authentication. It seems like FME does not have built-in support for OAuth1. Is there a way to set the HTTP caller in this case?
I would be extremely grateful if you could provide me with your assistance!
hkingsbury
Forum|alt.badge.img+73
  • Mar 20, 2024 8:15 PM UTC
FME Does support Oauth2, it nees to be setup as a webconnection - https://support.safe.com/s/article/Creating-Web-Service-Connections-OAuth-2-0
fme_can_do_it
  • Mar 20, 2024 8:25 PM UTC
@hkingsbury I need to make a REST API request to NetSuite and it requires OAuth 1.0.
hkingsbury
  • Mar 20, 2024 8:28 PM UTC
Reading this documentation it indicates the above should still work - https://docs.safe.com/fme/html/FME-Flow/WebUI/Web-Connections.htm
