Esri layer file source
  • June 15, 2020
  • 102 views
Can I read the info behind a lyr-files with FME? I am looking for a method to retrieve the source data of the layer via FME. And at best also the info of the legend itself (such as the font type used in the legend). Thank you very much
danilo_fme
Forum|alt.badge.img+45
  • June 15, 2020
Hi @geertrui
You can check all formats Reader and Writer in FME on this Link
The Reader Esri Layer is possible, you need that ArcGIS is licensed and the ArcGIS platform matches the FME platform
Thanks,
Danilo
