Encoding of diacritics in HTTPCaller
  • Oct 17, 2018 9:32 AM UTC
  • 83 views
friesewoudloper
Participant
When I do this api request using an HTTPCaller:
https://ckan.dataplatform.nl/api/3/action/tag_show?id=enquête
I get this error:
HTTPCaller_7(HTTPFactory): Received HTTP response header: 'HTTP/1.0 400 Bad request' from 'https://ckan.dataplatform.nl/api/3/action/tag_show?id=enquête'
When I do the same request from within my browser (Chrome and Firefox), I don't get an error.
I tried adding header parameters to my request:
Accept: text/html,application/xhtml+xml,application/xml;q=0.9,*/*;q=0.8 Accept-Encoding: gzip, deflate, br Accept-Language: nl,en-US;q=0.7,en;q=0.3
But this didn't work.
Something is going wrong when HTTPCaller encodes diacritics. How do I fix this?
Best answer by david_r
You have two options.
Either pass the parameter values through the TextEncoder set to URL-encoding first:
Or pass them through the query string parameters in the HTTPCaller, it will do the encoding for you:
  • Oct 17, 2018 9:42 AM UTC
nielsgerrits
Forum|alt.badge.img+67
Exactly this. In 2016 the body needs to be encoded too. Took me a while to find out strange API responses. Worked in test, failed in prod, no usable feedback :-)
